Thread: Car Alarm
Old Mar 27, 2012 | 12:10 PM
onehundred80
Default Re: Car Alarm
Originally Posted by jayaurtherrank
Can Anybody Help Me? My 05 Crossfire Will Not Start, Every Time I Open The Car Door The Alarm Goes Off And The Car Will Not Start. The Remote Fobs Will Not Unlock The Door Or The Trunk And The Battery Seems Fine. I'm Am Out Of Work And Cannot Afford Expensive Repairs. Please I Need Help.. Many Thanks
What makes you say the battery is fine? Do the lights work?
A simple and cheap test would be to disconnect the battery terminals, leave it for five minutes and reconnect after making the contacts, positive and negative clean and shiny. Also look at the ground wires.
Lift the carpet in the trunk and look down the back of the foam block in the trunk well, if you see water you have probably found your problem.
Inspect and report back, just believe we can solve this.
How old is the car, miles on it, model.
