Re: Lights start flashing for no reason.
I had to remove the battery cables 3 different times - that's why I threw that in as an after thought. It might have been what did it but the fix appeared to be the fob batteries. I know it doesn't make sense but it worked. Did you check the trunk for water while you were at it? It wasn't my problem but it would be another quick and easy check to do. Is is giving any kind of error codes at all?
