Old Mar 27, 2012 | 06:41 PM
onehundred80
Default Re: Fog lights and Side lights on.
Originally Posted by AmCross
I need a little help please. I came home and my 2004 limited coupe fog lights and right side parking lights were on and the battery was drained with the smell of hot wire. I took the negiative cable off to turn the lights out and the security whistle off after using the key to open the door. After that the fog lights wouldn't come back on but the side lights would when I charged the battery and put the cable back on. I took the fog light fuse out and then put it back in and the fog lights came back on. Now they still won't go out.
I have taken the fuse out of the right side parking lights and fog lights, checked for water leaks, now I need a cure for my problem.
I've owned the car since it was new and only have 11,024 miles on it and I've already replaced the steering wheel lock about 4 months ago. I guess it sits and falls apart if you don't give it attention.
My guess would be the security module under the foam in the trunk well. Has it been out in the rain? Water in this well really makes the lights and siren act crazy.
Just sitting there the water eats into the contacts and connections.
