Old Mar 28, 2012 | 02:15 PM
onehundred80
Default Re: 74mm Throttle Body, surging idle
All connections are sound and everything tight.
All I had time to do yesterday was disconnect the MAF and the negative battery terminal (30 minutes minimum) to get the ECU to reset. I test drove twice, and other than a little higher idle, it was fine. I got in this morning to go to work and the problem came right back.
I am going to swap the MAF sensor and see if that helps. Next move is to take apart the TB or swap back to the 68mm. I will keep updating the thread for the next guy
Did you install a new O-ring when you did the TB install?
