Thread: Convertible Top
Old Mar 29, 2012 | 11:01 PM
D. Lee Hendershot's Avatar
D. Lee Hendershot
Default Convertible Top
2006 roaster Top will not raise or lower when the temperature is around or above 80 degrees. Last summer dealer reversed relays on the hydraulic power unit. This spring (2012) I lowered and raised the top several times, with no problem. Last Friday the temperature was in the low 80's, and the top would not lower into the trunk after the deck lid opened. Could not close the deck lid. Parked the car in the garage, several hours later the deck lid did close when I activated the consol switch. I tried to open the top again. The deck lid opened. The top raised straight up and then stopped. Would not close nor open. Red led on consol flashes and beeps. Two days later the hydraulic pressure drained off, and the deck lid was against the canvas top. I pushed up the deck lid and the top lowered into the trunk. The deck lid droped down in position. Unable to open the trunk. Took car to the dealer the following Tuesday. They can not get the convertible top to malfunction because the temperature is below 80 degrees. They say there are no error codes. I think they should take a hair dryer or hot air gun to the control module to see if there is a defective component in the assenbly. Has anyone else had this problem or have a suggestion to correct this problem? Please email with a solution, lhendershot@aol.com
