Old Mar 30, 2012 | 09:03 AM
stevedask's Avatar
stevedask
Default Re: BAS EPS/ Brakes not working when brought out of storage...
Originally Posted by mysilverbullet
Not sure if bleeding it is part of the process but they quoted me for the master cylinder so I assume they are just replacing it....$$$
Hello,
So do you have any update - Did replacing the Masert Brake Cylinder fix your issue?
I'm waiting to see if that worked for you before I pull the trigger on a MBC replacement to try and fix my similar soft Brake issue.
I noticed by driving around a bit more the pedal is still the same "soft" but the light has never come on again.
Thanks,
Steve
