Originally Posted by jamesmcaleer
Hi guys, I have a problem, Sorry I sound like Tom Hanks in Apollo film,just underneath engine cover on crossfire ,there is a pump or electric motor that came on and would not go off even after switching engine off, I had to disconnect the electrical connection on it, this part is located at the top of the engine and is situated between what looks like 2 vaccuum mechanisms, at the top end of the engine,can anyone tell me what it does and what it is for, as car seems to drive as normal,I can`t find any online pictures of it to attempt to describe what it is and what it does,thanks guys,Teak
That motor is the secondary air injection pump/motor. It might be the Relay Control Module (RCM) has a stuck relay contact. I would pull the RCM and check all the relay contacts for burnt/fused contacts, and while it is out check/solder all the solder points on the back as well. This problem has been reported before and it was as a result of the relay 'fusing' shut and it would never turn off. Good luck!
