Originally Posted by blkXfire04
Well I replaced the fob batteries, I also went to the local place and asked if they would put it on the computer but they wouldnt b/c the check engine light wasn't on. So with new batteries in the key fob I gave it a try last night and it continued to do the same thing. So today I crawled inside my trunk and tried to get the foam off of the floor. With alot of cursing all I was able to do was mess things up in there. Even though I loosened the carpet I was still unsuccessful in lifting the foam inserts. So I say to myself, it's almost summer and if there is water under there somewhere it will eventully dry up. I figure if I have to disconnect the battery every freaking day until it drys up....then so be it. I anyone else has any idea what it could be Im open to suggestions. Could it possibly be a fuse somewhere? Thanks!!
Your grasping at straws, pull the foam sections (involving removal of the trim, I think the clips pop out after pulling up the little pins in them) and check for water in the compartment/modules.
