Old Mar 30, 2012 | 08:03 PM
GraphiteGhost
Default Re: Lights start flashing for no reason.
Originally Posted by blkXfire04
Have you ever tried to pull those up? I had all the pins out and pulled the carpet back but w/o pulling the plastic off and risk causing a bigger problem I decided to put all the pins back in once I couldnt pull up the freaking foam by pulling back the carpet. I have read 100 posts and they all say different things, none of them are conclusive. So I wait......waiting for the one person with the answer. One thing Im not sure of is the age of my battery but I had it tested and they said it was okie dokie
OK yeah, there is also some of those hidden plastic clips that are round, like pins that snap into holes. Those are the ones that are the worst. You will have to talk to someone who actually has taken out those rear trim panels so keep this post active for the folks that have had to take out those trim panels. I hope it isn't those modules (there are two one is the locking pump module I cannot remember what the other one is). Good luck!
