Thread: Temp problem
Old Apr 1, 2012 | 11:55 PM
James1549
Default Re: Temp problem
Sounds normal to me. When the gauge shows just above 1/2 mark, the fan comes on, and back down to just under 1/2 and fan goes off. It is a continuous cycle unless you are on the highway to get enough air through the radiator to keep cool.
James
Originally Posted by 2008XF
Hi
I drove my XF from toronto to windsor today which is about 400kms and the need went a little bit over the half way point when i got to windsor. i thought the problem was with the long drive, so i turned it off when i parked it for 2 hours and then went out for a spin, and the temp needle would go over the half way point just a tiny bit, and then would go under the half way point, never had the problem before
