Re: 74mm Throttle Body, surging idle
Glad you found the fix. You were certainly methodical in your pursuit. Wonder if this may be my cold air issue too, where when the car is cold start below 40 degrees it just stalls and no pedal response, and this was after the 74 mm TB, with the 68 before it was just fine. I don't think it is because above 40 it's fine.
