Old Apr 2, 2012 | 04:26 PM
James1549
Default Re: Use 9005 bulb in fog lights?
To use a 9005 in a 9006 socket really is not a good idea for two reasons. First you must modify the plug to make it work. Second, the sealing surface at the O ring is a different size, actually a lot smaller allowing dirt into the housing. Put them side by side and you will see the physical difference.
