Old Apr 3, 2012 | 06:16 AM
  #60 (permalink)
velociabstract's Avatar
velociabstract
Default Re: Lowered cars... improve your ride...
I'm surprised about the sudden appearance of contact with the adjustable links. I had the same contact a few years ago. I switched out the blue Ebay camber arms for Speedybenz's (before Mike started making them) and the contact was less, but still there. In the end, the solution was to grind a little clearance in the body seam. I used a grinding stone on my drill and sealed it afterwards. You could probably get it done with a half round file if necessary. The other solution is raise the rear of the car until it doesn't hit. Or the original arms with Kmac. Or put it back the way you had it before. Not wanting to grind clearance on my car I put up with some contact for a long time. When I installed the variant II's I bit the bullet and got out the grinder.
Les
