Awesome exhaust system for $275
Anyone interested in a cheap alternative, to the high priced Borla, exhaust system that is a quick and easy bolt on? Like most X-fire owners, I was a little frustrated that no one makes an affordable quality built and sounding exhaust system. The cheapest built, that I know of is Borla for around $600. I built a quick and easy clamp on that uses the factory hangers and/or bolts to existing chassis bolts. I used mandrel bent 2 1/4 tubing (factory diameter) and a polished stainless steel ARC performance muffler. It has the same look as the Borla and sounds awesome. Not too loud, but definitely not quiet. I am looking to see how many people would be interested in it and I will put together some kits, with everything you need to install it, plus instructions. Let me know if you are interested and I can also send pictures. I plan on selling the kit for $275. It looks like a factory set up. I plan on going to the drags to do a run before and after the system is installed to get the gain in the 1/4 and approximate the hp gain.
