Originally Posted by alaxfire
OK, I'm sure this must have been asked before, I searched and couldn't find it though ....
1. did you make those little side wings yourself also ?
2. What caliber and what is the rate of fire on the 2 guns you have behind the lower grills ?
( look like 20 mike-mike to me
And lastly, put me on the list if you decide to make more of those gorgeous grills !
Right now the lower grille port hole helps cool off the supercharger's water pump. The drivers side lower grille port goes to....
Well nowhere! May install round LED lights in them one day..........The side wings front and back fender spoilers were cut off the ends of two Pontiac GrandAm's rear deck spoilers. Filled with styrafoam <(spelled wrong) then a 1/8th layer of QuickSet50 Epoxy so I would have a good surface area for mounting with body side moulding tape. Squirrel Crusher
