Old Apr 4, 2012 | 10:09 PM
onehundred80
Default Re: Differential help
Originally Posted by velociabstract
My differential has to come apart, again, in the near future. I need a little help identifying the correct parts. I already have the side bearings but if anyone has the seal part numbers please post them up. I want to buy an assortment of adjustment shims beforehand too. What are they called exactly? I want to have the parts in my hands before digging in. Yes, it's singing and getting worse. The plan is to pull the cover, use some machinist dye to check the pattern on the ring and pinion, and fix the sucker for good. So, what are those shims called so I buy the right parts. Thanks for the help. Oh, back to the dyno tomorrow to check the latest tune. Next ...... well, it's better to do it and tell afterwards.
Les
The standard components should be here.
