Old Apr 7, 2012 | 04:29 PM
maxcichon's Avatar
maxcichon
Default Re: door speakers blew and clueless on replacement
Originally Posted by sk8erjosh09
If I remember correctly the amp only puts out 22W RMS, so 180W speakers (probably peak, so 90W) would require more power to remain constant. Not that its a huge deal (Im currently underpowering subs) but you may want to find something with less peak/RMS. Im picky with speakers and usually stick with Kicker, but you should check out Kenwood or MTX as well. Try to find a speaker to match the current amps output. Or buy componet speakers with amps all ready to go. Hopefully this helps.
These Infinity's are quite efficient. Their power handling capability is really not an issue.
Much louder (crude way of putting it!) for a given "volume" setting than the OEM things. And much better sounding. Try it-you'll like it!
