Old Apr 12, 2012 | 08:33 PM
JesseJamessrt6's Avatar
JesseJamessrt6
Default Re: New Wheels in, need help
Just to make you feel better, I am running:
19 X 8.5" 35 mm Offset front wheels, 235/35 X 19" 10 mm spacer (25 mm effective offset)
20 X 9.5" 35 mm Offset rear wheels, 275/30 X 20 15 mm spacer (20 mm effective offset)
Eibach Sport springs, Adjustable rear arms (I made them )
Doing the math (crayon and matchbook time!)
You'll need 20/25 mm spacers in front to make it like mine (23/18 mm effective offset).
You'll need 20/25 mm spacers in back to make it like mine. (23/18 mm effective offset).
You adjust/massage the spacer thicknesses, but I think they come in 5 mm increments.
Mount the tires-Measuring the wheels hanging in space really doesn't help. The suspension swings out a bit in extension.
What you have should work with correct spacing. My rears were tucked in a bit before lowering-now they're as close to flush as possible. Check my gallery.
Looking at your pics, your front wheels with a 25mm effective offset don't stick out past the fenders like mine are looking with an effective 23mm offset (43mm with 20mm spacer), and this is only a 2mm difference. The fact that I don't have tires and not sitting on the ground has got to be giving the false illusion....
