Re: Left headlight burnt out!!
You say left headlight is that high or low beam, we take left to be the driver side - fuse 8 low beam, fuse 5 high beam. Passenger side, fuse 6 low beam, fuse 3 high beam.
You were asked if the high beam worked but you gave no answer. Answering questions helps diagnose problems, ignoring what may seem a stupid irrelevant question does not help.
The fuse is OK you say but is there any power going to the socket? That is the first step to take, you work back from there, check the fuse in the other side headlight. Sometimes fuses look OK but are faulty in some way.
