Old Apr 13, 2012 | 02:14 PM
onehundred80
Default Re: Changed my air filter...?
Originally Posted by jlw
Yes, two filters changed, sorry bout that. I had the codes checked and it had three different code numbers which I did not write down. Standard o2 sensor to lean code, code for bad gas (which I can rule out at this time), and a leak in the manifold which would be I guess, air intake valve or the mass air flow sensor.
I am going to check the connection to the air intake valve and the ma sensor this week-end.
Thanks for your help
When I first got my '05 I found the engine cover was not down tight and I had no codes set and everything seemed fine. But another member here had a tear in the donut seal on the engine cover to MAF and did have a problem the cause of which was not easily seen. So check the seal for rips and tears.
