Old Apr 14, 2012 | 09:27 PM
  #41 (permalink)
robertalive's Avatar
robertalive
Default Re: 74mm Throttle Body, surging idle
Boiler that irregular idle is normal for 100 to 200 miles til the computer adjusts.i dont use rtv on the throttle body.i used mercedes gasket sealer ,its a little different,and you must let it sit for 5-8 hours,i usually go to sleep and give it at least one whole night.you must scrape and clean the throttle body allow the gasket sealer to sit for a couple minutes to release gasses.then bout 5 mins later install and bolt,trying not to smear any sealer.tightin bolts to specs or there about.reconnect all.and it should act stupid up to bout 200 miles then youre good.when i did mine i noticed a good increase and took the car to dinner at the olive garden she had a good time so when we left the problem was solved and we were friends once again.
