Originally Posted by 67wildbill
Hey Fellows need help.my wife's is acting up to.changed fluid & filter about a month ago.now sometimes when it gets warm it's like the rpm's go way up but your not going anywhere fast.is it in the limp mode.also jut replaced the connector about a week ago.it was leaking.what about this electrical plate or maybe bad solenoids.05 limited.Thanks Bill Fields
Hard to say, but if you just had transmission serviced and connector replaced, it sounds like it may be related. Maybe there wasn't enough fluid put back in the tranny. Possibly when the connector was replaced it wasn't attached properly. If could be a bad plate but if you weren't having problems before they are likely are result of the recent work.
Check the connection to the connector. Make sure they isn't a resulting leak from the previous work. Check the fluid level carfully. Beyone that, seems like you'll have to go to an expert.
My bet is on not enough fluid, or the wrong type of fluid.
Good luck.
