Originally Posted by robertalive
Boiler that irregular idle is normal for 100 to 200 miles til the computer adjusts.i dont use rtv on the throttle body.i used mercedes gasket sealer ,its a little different,and you must let it sit for 5-8 hours,i usually go to sleep and give it at least one whole night.you must scrape and clean the throttle body allow the gasket sealer to sit for a couple minutes to release gasses.then bout 5 mins later install and bolt,trying not to smear any sealer.tightin bolts to specs or there about.reconnect all.and it should act stupid up to bout 200 miles then youre good.when i did mine i noticed a good increase and took the car to dinner at the olive garden she had a good time so when we left the problem was solved and we were friends once again.
I would think the 1000+ miles I put on it would be more than enough to let the ECU learn the new TB. Since it is an intermittent issue, I do not think it is a vaccuum leak, either. Red RTV is gasket maker, IMO same stuff in the MB bottle, just less expensive and readily available.
Thank you for the ideas, just don't think thats the issue.
