Old Apr 16, 2012 | 07:44 PM
ala_xfire
Default Re: 2008 Crossfire valve cover leak
Originally Posted by fh69
I have a 2008 crossfire with less then 2000 miles on. I am the second owner so the lifetime powertrain warranty does not apply. I have a small oil leak from the driver side valve cover and need advice on how to have it repaired. This is apparently a common problem so is it covered by Chrysler? If not, any ideas about the cost to have it repaired?
I doubt Chysler will cover it.
easy DIY - this is the very first repair I had to do after buying mine .
About $5- $10 and 2 or 3 hours.
get a set of male torx bits. ( get a set of female torx sockets too, if you can find them, if not order from Amazon )
Use the BLACK RTV sealant. ( I used Permatex 'Ultra Black', but there are many other choices )
DO NOT over torque the aluminum screws, just over finger tight.
CLEAN BOTH SIDES thoroughly before applying the sealant.
Let them sit for about an hour before putting them together.
( do the passenger side too, while you are at it )
