Old Apr 19, 2012 | 05:40 PM
  #114 (permalink)
rcompart's Avatar
rcompart
Default Re: DIY Transmission leak fix with photos... TA DAAaa
Originally Posted by cubanbee
Im not ure what happened or were the leak is coming from but i went to tune my tcm with jerry and it was covered with trans fluid so i dug a little deeper and there was a mini puddle where the tcm it was fried, i have the new tcm on the way but i cant find the leak and where it could be coming from i told the transmission shop i took it to to go ahead and replace the seal but i think all they did was replace the transmission dipstick cap and seal. anybody have any ideas?
I have the new tcm coming in tomorrow and i dont wanna go through the same problem again.
I find that highly unlikely as we get them in quite often with fluid in them and a quick clean up and they are fine. Unless it was plump full, that wasn't what caused your TCU to fail. I'm not sure what changed between when yours worked and when it stopped but I'd look things over before plugging the new one in.
This is very odd and requires further investigation. When I did my Paddle shifter install back in December the mounting plate in the passenger side footwell where the TCM and Audio Amp is mounted was high and dry. A couple weeks ago I went to swap out my TCM with a tuned one and found an oily substance on the bottom edge of the mounting plate. I thought it was strange but cleaned it up and continued on. I think we need to ask Rudy for his expertise as to where this oil can be coming from. Now it seems that we need to worry about enough oil there to fry components?.
I think we should all be concerned.
The oil is wicking up through the trans wiring harness. It is a direct result of the trans connector seal failing. Only way to get rid of the fluid is to fix the connector seal.
