Old Apr 19, 2012 | 09:01 PM
  #115 (permalink)
SparkieSRT6's Avatar
SparkieSRT6
SSB SRT6 405hp/401Tq
Default Re: DIY Transmission leak fix with photos... TA DAAaa
Originally Posted by rcompart
I find that highly unlikely as we get them in quite often with fluid in them and a quick clean up and they are fine. Unless it was plump full, that wasn't what caused your TCU to fail. I'm not sure what changed between when yours worked and when it stopped but I'd look things over before plugging the new one in.
The oil is wicking up through the trans wiring harness. It is a direct result of the trans connector seal failing. Only way to get rid of the fluid is to fix the connector seal.
Rudy, thanks for your insight.
So it can actually wick up ! I guess I better buy another seal as I just did mine 6,000 miles ago.
Could the oil be from the first leak and I just never noticed it the first time? Although I was under the car last weekend when I did the steering damper and noticed some residue around the gland fitting but none on the pan. What a PITA.
