Old Apr 21, 2012 | 09:04 PM
Crossfire725's Avatar
Crossfire725
Default Re: Front and rear spring removal procedure write up
Originally Posted by 32krazy!
removing the bolts are not only dangerous and tedious to get back in under the pressure of the spring you have also removed the alignment of the car. now you spend a 180$ to get it properly aligned when you could have spent that on a proper spring compressor and done the job in less time safely.
i have doen this both ways and would never try it again without the compressor. 30 min each side with it and no worrys about getting hurt
i felt safe the entire timenot enough tension to really be dangerous. your putting a little tesnsion with the jack, nothing to be afraid of. and about the alightment, when you lower you car an alignment is needed either way if u want to do it by the book. i undertand what your saying i dont disagree with it would be easier with a compressor but this way is very doable and easy. and get the job done in just under an hour eacxh side.
