Old Apr 21, 2012 | 09:18 PM
32krazy!'s Avatar
32krazy!
Default Re: Front and rear spring removal procedure write up
Originally Posted by Crossfire725
i felt safe the entire timenot enough tension to really be dangerous. your putting a little tesnsion with the jack, nothing to be afraid of. and about the alightment, when you lower you car an alignment is needed either way if u want to do it by the book. i undertand what your saying i dont disagree with it would be easier with a compressor but this way is very doable and easy. and get the job done in just under an hour eacxh side.
if you dont think 400 plus pounds of spring tension can do any damage you are sorely mistaken. of course it CAN be done this way. you could also remove the wheel and work on the suspension with no jack stands but is it safe? hardly.
try it once with the proper tools and you wouldnt even think to do it the other way
