Re: Manual Transmission Swap
If you have a ton of money to burn try Xtrac in Indianapolis. They'll build you any gearbox differential combo you could dream of!!!
The whole concept seems a bit crazy to me... It would probably be easier and cheaper to do it the other way around. Drop a SRT6 motor into the Limited. Everything will line-up and you won't have to manufacture a clutch pedal into the car... Good luck...
