onehundred80
You mean rocker cover gaskets I take it?
I nipped mine up once, not too much though, just a tweak.
Forgive my ignorance as to the location, I'm thinking these are the cylinder head cover bolts. I attached a pic. You can see the little bit of oil I am referring to just right of the spark plug.
I found the torque specs from the manual you posted for someone else. Are these the cylinder head cover bolts that should be 7 ft/lbs?
