Old Apr 28, 2012 | 01:22 PM
blackbelt_010892's Avatar
blackbelt_010892
Default Re: Left Front Turn Signal Problem
Originally Posted by Ronman
My left front turn signal works and then stops working randomly. There is nothing wrong with the bulb or the fuse.
When I remove the bulb, one of the contacts inside the headlight has a hole in the middle of it. When it is not working, if you touch the turn signal from behind sometimes it will work, so there is bad contact.
Am I basically stuck buying another entire headlight assembly?
There is a socket turn signal part 5174703AA but I assume that is what the bulb goes into and then is put inside the headlight assembly?
Any suggestions would be very very appreciated.
I was stuck getting two new headlight assemblies a few months back because of the exact same problem.
