Old Apr 29, 2012 | 07:25 AM
Chris L.'s Avatar
Chris L.
Default Re: I am looking at buying a 2007 coupe...l Need advice!
I'm the original owner of an 07 Limited (stick) 6 spd. I've put almost 78,000 miles on it so far. I've only had 2 problems....tiny leak in valve cover gaskets & tiny rear axle leak.....I probably wouldn't even have gotten those 2 things fixed....except they were covered by my Lifetime Powertrain Warranty...so why not.
I do mostly highway driving & as such average a hair over 25 mpg.
The FSS (oil life monitor) will let you go >8,000 miles between oil changes.
I got mine up to 131 mph once (in 5th) before I had second thoughts about the age of the tires.
Also the cooling fan got weird for a few hours once after I took it up over a hundred when it was minus 5 degrees F outside. After a while it's little brain reset itself.
