SRT6_Roadster
Yes, but there is a big difference between NA and FI engines. The SLK350 needs to suck in the air the SRT-6's SC will force the air into the engine. Backpressure is much less of a concern with an FI motor and in the case of a turbo motor the less back pressure the better (the sooner the turbo will spool up).
was gonna say the same thing, When correctly done, You can see Huge results on a forced induction engine. You can see first hand on the E55 forum, a member there opened a set of factory manifolds and the internal pipe is like 1.25in! Crazy! So thats one reason headers and a larger diameter mid pipes can yield 50+ HP on those. I bet it would be around the same or just a bit less on a modified 32 or SRT.
