SparkieSRT6
Just want to add that step #2 can be a PITA if you don't spray a little silicone lube through a straw into the end of the parking break rubber sleeve. Slides off real easy with some lube.
Lube is the key as stated, It was really easy using alcohol spary to get it off and hand sanitizer gel to install, it evaporates and leaves it sticking in place after the slipperiness evaporates.
