Old May 2, 2012 | 09:40 PM
waldig's Avatar
waldig
Talking Re: Anyone running two IC pumps?
32crazy are you using the factory to factory IAT readings?? You should cool much faster.
Did you gasket the core so that all the fan air goes thru the supercooler? Air will shunt the cores if there is any gap, reducing the benefits.
Here are some of my photos and videos, I got 4.0 GPM with the lower restriction HE and the better pump from Needswings. Stock flow was about 1.5 GPM. Enjoy. Woody
Heat exchanger up grade for SRT-6 part 3 - YouTube
https://www.crossfireforum.org/galle...y.php?cat=1728
cooling photos
MIR race of Crossfires - YouTube
Cooling video on track, check out the delta t across the heat exchanger, left hand meter.
Woody
