Old May 2, 2012 | 10:33 PM
onehundred80
Default Re: Alarm won't turn off :(
Originally Posted by nickwe21
Read through most or all of them and did not find a suiting fit. On most of the threads the alarm turns on and off randomly and some can't start their cars. My car starts perfectly fine but the alarm always sounds...I pulled the fuze and as soon as I reattach it the alarm goes right off whether the ignition is started or not. Thought someone actually found a real fix for this problem!
First place I would look is in the trunk under the foam, the central locking system/security module is there. Water leaks into this area can be tricky with the side effects.
Lift the carpet and peer down the forward end and look for a small swimming hole.
