Old May 3, 2012 | 10:54 AM
  #80 (permalink)
BoilerUpXFire
Default Re: 74mm Throttle Body, surging idle
Ooookkkaaayyyy,
first leak found was: (drumroll) drivers side intake manifold/head gasket. It's never been off, but he said that carb cleaner sprayed in the area shows a leak there. At the front.
I'll keep y'all posted.
Wow, I did the carb cleaner, torch, and smoke tests on mine and there were no leaks. Damn this issue is confusing as it is manifesting itself a little differently in each car it affects...
Thanks for the update, Max (Picasso )
