WestKyOnXFire
I have a NW CAI on the way, so I don't need the housing. Am wondering if any of you may know where to try, have checked ebay and amazon ofc, but those all have the MAF housing as well.
Thanks in advance.
I'm pretty sure the new style NW CAI re-uses the 90 degree plastic elbow and the plastic MAF housing.
Check with Rob, if so you will need a 74mm MAF housing also, but re-use the original MAF sensor, do not replace with the MB 74mm MAF sensor.
( You could also ask Rob if he has any of the old gen 1 CAI's left - these do NOT use the plastic stuff,
there is a bung for the MAF welded into the pipe just before the 90 degree bend. It then connects to the TB with a 90 degree silicon coupler hose - this is what I have )
