Old May 7, 2012 | 10:21 AM
onehundred80
Default Re: Alarm won't turn off :(
Originally Posted by nickwe21
Got it! I'm going to take a look at this later on when I get back from work. Thanks for the explanation, I had the feeling I might have to take those 2 panels off in order to get the foam out. Damn car alarm! lol
I said you can look down the gap, any water should be visible. Stick a thin object down there, if it comes out wet you know you have a problem. Also, as GG said you can get under the car and pull a plug out. Taking the foam out should not be required unless you have water in the well.
