Re: Changed my air filter...?
The throttle body was loose, the bolts were not very tight. I cleaned the tb and replaced the o-ring. Pushing down on the airfilter must have broken the seal made by the silicon gasket causing a small air leak. $18.00 for the o-ring. I did not use any silicon gasket material, o-ring only.
