Old May 10, 2012 | 09:08 PM
JesseJamessrt6's Avatar
JesseJamessrt6
Default Re: Spring and shock install?
a lift will be safer than jack stands. You may gain some working room but not much. The jack needs to help push the A arms back into place to line up the holes to insert the bolts so it will have to be lowered to the ground at the end to use the jack to do this.
