WestKyOnXFire
I was under the impression that adjustable "rear camber arms and spacers" was the rear camber kit... Also, Les, I have a spring compressor, bought one when I did the accord and used it for the Talon as well. I have helped a couple of people that preferred to not use the compressor the first time, but ended up using it on the other three wheels. SO MUCH EASIER
Edit: Forgot to mention mine is the '04 6-speed.
Correct about the rear camber kit being the rear camber kit, I was saying that on Needswings website, they only have the front collision repair bolts for sale, not the KMac kit, as you suggested you got everything from Rob. These bolts will only get your a few tenths of a degree of change, so if you lower it more than an inch or so, plan on buying the KMac kit for your FRONT comber issues.
You will use the compressor on the front for sure, but not the rear...
