Intercooler Reservoir + Custom Cap
May 14, 2012 | 12:45 PM
permalink
Daniel454
Sep 2010
246
(South of) Huntsville, AL
Following in the footsteps of many, I decided to not only isolate the Intercooler and Radiator Coolant, but to add a reservoir as well. Looking through what others had done, I didn't blaze a new path, but rather took a little bit from many and made it my own.
I couldn’t find EXACTLY what I wanted so I started with this reservoir and mounting bracket from Jegs…
JEGS Round Recirculating Overflow Catch Can with Fill Neck
JEGS Catch Can Mounting Bracket
Not liking the small ¼” Nipple, I drilled and tapped it up to a ½” NPT and used this ¾” Hose inlet from Summit…
SummitRacing Tuff Stuff Hose Nipple 4450B
Mounted it to the radiator fan housing (using massively large fender washers on the back to ensure no risk of the plastic giving or deforming).
Capped the connection from the intercooler system going into the factory coolant box, piped it to my new reservoir.
Added a custom radiator cap
And here you go….
The Custom Cap mounts to a standard radiator cap. I ordered it through a company I deal a LOT with for my other vehicles (Magnum and 300C).
Billet Technology | Modern Mopar Billet Accesories
Most of what they have won't work on the Crossfire but since this used a standard radiator cap, it worked just fine.
Billet Radiator Cap Cover
10:43 PM
Daniel454
View Public Profile
Send a private message to Daniel454
Find all posts by Daniel454
