Old May 14, 2012 | 09:49 PM
JesseJamessrt6's Avatar
JesseJamessrt6
Default Re: Intercooler Reservoir + Custom Cap
Originally Posted by Daniel454
Yes, I picked up some 3/4" heater hose from Auto Zone and ran it straight to the bottom from the T. Capped the outlet on the bottom of the Factory tank.
I actually just plugged the overflow vent from the jegs unit...
It could easily be ran in to the factory overflow box from there but I didnt because the pressure , nor heat of this system should ever be enough to actually cause the radiator cap to pass / vent any fluids...
Really, the cap is nothing but a way for me to check and add fluid as needed more than it really is going to be for any type of venting.
Thanks for the info, last couple of questions.
What did you use to cap the bottom of the factory tank?
So that makes four caps all together, one 3/4" for the bottom of the factory tank, and two smaller caps (one for each end of the factory vent), and the last one on the vent of the new jegs unit.
What was your cost in all (without personal discounts)?
