Old May 15, 2012 | 11:16 AM
aallman72's Avatar
aallman72
Default Re: Transmission or Clutch?
Originally Posted by arejohn
http://homepage.mac.com/gregmeach/XF...r_6-Clutch.pdf
Check fluid. Look for fork movement. Cracked pressure plate or spring.
From the PDF:
"The clutch release bearing is integrated with the clutch slave cylinder for smooth operation. By eliminating the clutch release fork, less effort is required to release the clutch."
So I am assuming there will be no fork to check?
