Old May 16, 2012 | 11:11 PM
onehundred80
Default Re: Transmission or Clutch?
Originally Posted by aallman72
Also can anyone look at the above photo set and tell if its a dual mass flywheel?
Dual mass flywheels have the springs in the flywheel, the simple clutch has the springs in the clutch plate. These are dual mass. The plate movement should be no trouble, that will allow the holes and bolts to line up.
Additional info.
http://www.honestjohn.co.uk/faq/dual-mass-flywheels/
LUK clutch failure diagnosis
http://www.schaeffler.com/remotemedi...ose_pkw_en.pdf
