Old May 20, 2012 | 07:17 PM
mickland's Avatar
mickland
Default Re: Start & Stall Issue
Put the Bosch CPS sensor in last weekend and the misfire was gone, still feels sluggish in the low RPM, particulary in 1st and 2nd gear but still better than it was. Will switch the camshaft position sensor back to an OEM Bosch part and see if that resolves the performance issue. If either of your cam or crank sensors go I suggest you replace them with OEM Bosch parts. Thanks.
