Old May 20, 2012 | 10:02 PM
  #48 (permalink)
JesseJamessrt6's Avatar
JesseJamessrt6
Default Re: New Wheels in, need help
I finally got the suspension to the right height front and back. I ended up with 4 dots on the rear and 5 dots on the front and although it is not as low as I would like it the rubbing is mostly gone even with aggresive driving.
So to sum it up;
Front-
TSW Max 19"X8.5" et 43mm with 12mm hubcentric spacers for an effective 31mm offset, wrapped in 245/35ZR19. The OEM springs were cut 7/8 of a coil and 1" off the shock bumper and 5 dot spring pads.
Rear-
TSW Max 20"X10.5" et 40mm offset with 15mm hubcentric spacers for an effective 25mm offset, wrapped in 285/30ZR20. The OEM springs had 1 full coil cut off and 1" off the shock bumper with 4 dot spring pads. MikeR adjustable camber arms and sway bar links with modification to the body seam to allow increased upward travel of the sway bar.
I still hear a little creaking from the back that was not there before the suspension modifications that I am still trying to chase down.
