Old May 23, 2012 | 05:31 PM
  #61 (permalink)
onehundred80
Default Re: Transmission or Clutch?
Originally Posted by aallman72
I have a question. If you look at the transmission input shaft you'll notice the splines look pretty dry. The clutch kit came with a little packet of spline lubricant. Is that supposed to be lubricated? Why is mine bone dry?
I am assuming I should put some on the transmission before bolting it up. Or is it for other applications that use this kit, just not the crossfire?
I guess yours dried up over time, the plate slides up and down a bit on the splined portion of the shaft so you do need it. Not too much or it will get thrown onto the friction pads.
If you are using the old flywheel then you should scuff it up a bit with emery cloth. You can buy the disks and the spindle they run on in a hand drill quite cheaply <$20. They are made for disk brakes.
Running a dial indicator over it should be done as well, just in case it is badly warped.
