Old May 23, 2012 | 07:53 PM
Cedar11's Avatar
Cedar11
Default Re: Braking Vibration
Originally Posted by velociabstract
First, check that the lugs are torqued correctly. Next check that the front rims aren't bent. Do you have spacers? I find it unlikely that the front rotors are warped under normal usage and my best guess would be a bent rim.
Les
I do not have spacers, everything is stock except the sound system. I have looked at the front rims and they do not appear to be bent. If they were, wouldn't it cause vibration without braking?
I will apply brake grease to all the pads to see if it helps with the squealing.
Thanks for the input guys.
